2013 GT Misfire
jj89gt
Has anyone heard of the new 2013 GT misfiring. Cyl 1 and 4. I was told ford is working on a software update because they don't have a fix for it right now. It only does it sometime. They told me the car is safe to drive
FORD:
2011 2012 Mustang
ISSUE WARRANTY STATUS: Eligible Under Provisions Of
Some 2011 Mustang vehicles equipped with a 5.0L New Vehicle Limited
engine and built on or after 8/17/2010 may exhibit a Warranty Coverage And
malfunction indicator lamp (MIL) on with one or Emissions Warranty
more of the following diagnostic trouble codes Coverage
(DTCs) stored in the powertrain control module IMPORTANT: Warranty
(PCM) memory: P0301, P0302, P0303, P0304, coverage limits/policies are
P0305, P0306, P0307, P0308, P050E, or P2610. not altered by a TSB.
Warranty coverage limits
ACTION
are determined by the
Reprogram the PCM to the latest calibration using
identified causal part.
IDS release 73.04 or later. This new calibration is
OPERATION DESCRIPTION TIME
not included in the VCM 2011.5 DVD. Calibration
110703A 2011 Mustang: Check 0.3 Hr.
files may also be obtained at www.Motorcraft.com.
DTCs, And Reprogram
NOTE The PCM (Do Not Use
With Any Other Labor
PLEASE ADVISE THE CUSTOMER THAT THIS
Operations)
VEHICLE IS EQUIPPED WITH AN ADAPTIVE
DEALER CODING
TRANSMISSION SHIFT STRATEGY WHICH
CONDITION
ALLOWS THE VEHICLE’S COMPUTER TO LEARN
BASIC PART NO. CODE
THE TRANSMISSION’S UNIQUE PARAMETERS
RECALEM 04
AND IMPROVER SHIFT QUALITY. WHEN THE
ADAPTIVE STRATEGY IS RESET, THE
COMPUTER WILL BEGIN A RE-LEARNING
PROCESS. THIS RE-LEARNING PROCESS MAY
RESULT IN FIRMER THAN NORMAL UPSHIFTS
AND DOWNSHIFTS FOR SEVERAL DAYS.
