Excessive oil in odd places.
Ashira
So i was cleaning the engine bay in the cobra yesterday and i took off the tubing between the MAF and the throttle body only to have oil start running out of it. I understand that you might have some in there because it connects to the passenger side valve cover but should it be enough to where it pours out?
'03snkbt
use to have same issue until i went pcv delete...
prior, the only thing that helped some, was putting a breather in my oil fill location and changing pcv more often. slowed it down some and no performance issues.
worth a try.....and i have some breathers FS in the classified section.
