Forsale 99-04 GT Parts
Ashira
Im trying to clean out my and have a bunch of stuff i need to get rid of. All parts came off of a 2003 Roush Stage 1 with 70k miles.
-Stock driveshaft
-T-3650 (70k miles all gears work)
-Stock clutch
-Stock block with rotating assembly (70k miles)
-Stock PI heads (Has cams but no rollers or valve lash adjusted)
-Stock PI intake manifold
-Moroso Aluminum valve covers (brand new in box)
- Set of 4 original Roush Argent silver rims with Eagle GT wheel
-Stock black hood (minor scratches)
-Stock oil pump w/ pickup line and oil pan
-Stock brake system includes rotors, calipers, and new brake pads
Ashira
Few more things to add.
-Stock radiator
-Steeda CAI
-75mm Accufab throttle body and upper intake plenum (Polished)
-Stock coolant expansion tank
Ashira
Actually they are the 4 piston ones. Whichever ones come on the GT which should fit your car. So yes i would sell just the front 2. I also have the rotors if you need them.
Ferocious
Chula Vista
I believe the 2-piston calipers are the ones that fit. 4 piston are cobra brakes no? How big are the rotors? If they are 13" then you have the cobra setup i believe. If you can text me pictures of the calipers when you have time, that would help alot.
My # is 619-942-4108
- Steven
Ashira
it isn't a cobra setup I'm positive about that. its whatever comes off a stock GT. Im out of town right now but ill hit you up when i get back on wednesday.
