Chaz Spaulding
Chazstang
I have : Global West rear control arms, front and rear springs, Two different torque-arms (one is for an aluminum differential cover, the other the factory cover- but only one set of assembly parts) and caster/camber plates. A Global west-strut tower brace, as well as a JBA strut-tower brace.
Precious Metals front control arms to go with the springs.
Also, if you buy, you can have a set of Yellow Konis (one of them is blown but was undamaged by use) The other is fine. Theoretically you could either buy one new one or maybe try to get Koni to rebuild one. I will never again buy Koni because of too many failures with no damage inflicted--- your call.
Also I have an unused Wild Rides upper battle-box set you can have with this combo. All parts except the one Koni are in excellent condition and worked beautifully on my Fox with stock front and rear sway-bars.
Note that the G.W. strut-tower brace is brand new, un-installed as well as the G.W. torque-arm for the aluminum cover.
