Foxbody_Rick
Avid Foxbody fan
The heat in my car does not work. The blower motor does run and the real problem is when you insert a fuse into the fuse box, it literally melts the fuse, it doesn't blow. With winter coming up, this is a problem as i drive it alot. I am 90% sure it has to be a wiring problem(probably a bad ground or a bare wire). I just wanted to see if anyone else has encountered a similar problem with their car or maybe provide a detailed description of the blower motor wiring. Thanks
