it looks like the MGW is made with a better quality, but also looks like it does not set in the shift boot as well. the steeda tri has adjustments the lower or raise the heighth of the handle, but when lowered it looks like it will rub a hole in the boot. pro 50's shifter looks like its placement is better in the boot, but might have you leaning over reaching for gears. maybe after addding a roush handle to the pro 50's will give better reach and be the most succsessful shifter.
What I have observed is that the pro 5.0 is fantastic on cars with the T5 (SN95's like yours) on an S-197 it is a different set up and requires some fiddling. We put one in NorthernCountry's 2007 GT and it was very stiff in 5th and reverse. You should be very happy with the Pro 5.0 in an 02 GT.
because i prefer very short throws in a transmission, and while the steeda has a shorter throw than stock, it isn't as short as i would like it, and yes i have the handle in the lower adjustment
