luckychance
i got a bbk back in november but have been having one issue after another with it and after finally having it in my hands and trying to install it with some buddies have ran into a snag and hoping you guys could help out as i am at my wits end. the fronts are stoptech calipers and have 2 bleeder screws, 1 on the outside and 1 on the inside. when i bleed the outside passenger bleeder the pressure causes the inside one to pop open the rubber grommet, even though its closed. i have tried screwing everything down, at which point, no fluid should come out anywhere but still when i press the brake pedal, the bleeder on the inside pops the grommet and sprays fluid everywhere. havent installed the driver side yet. what gives? i had a powdercoat shop dissamble/reassemble the calipers so im thinking maybe there is a leaking seal on the inside? please help as i havent driven my car in 4 weeks and getting antsy going through withdrawls.
