JEGS SPORT STAR CAST WHEELS
Front : 15x4 W/ 1.75 BS , PN: 555-67051 , 3/8" Spacer ,PN: 555-65051
Rear : 15x8 W/ 5.5 BS , PN: 555-67077 ,NO Spacers , NO Relocated Swaybar , both front and rear use factory length studs and stock conical style lugnuts
JEGS SPORT LITE CAST WHEELS
Front : 15x4 W/ 1.75 BS PN:555-67001 , 3/8" Spacer PN: 555-65051 , W/ slight caliper grinding , 3.315" studs were used PN: 070-100-7722 , and 60* conical lugnuts PN: SUM-7540162
SUMMIT 541 SERIES WHEELS
Front : 15X4 W/ 1-3/4BS , PN: SUM-541-5465PS , 5/16th’s Spacer MRG-2371 W/ Slight caliper grinding , or 3/8" Spacer ,PN: 555-65051 and NO grinding
Rear : 15X8 W/ 5.5BS PN: SUM-541-5866PS ,NO Spacers , NO Relocated Swaybar , both front and back use factory length studs
WELD RACING 90 SERIES DRAGLITE
Front : 15X3.5 W/ 1.75 BS PN: 927-90-54340 , 3.315" studs were used PN: 070-100-7722 , 7/16" Spacer PN: MRG-2372
Rear : 15x10 W/ 7.5 BS , PN: 927-90-510354 Grind Calipers , NO Spacer , Relocate Swaybar , back uses factory length studs and weld/holeshot style shank lugnuts
BOGART RACING WHEELS
http://www.bogartracingwheels.com/
Front : 15x3.5 W/ 1.25 BS or 15x4 W/ 1.75 BS
Rear : 15x9.75 W/ 7.25 BS or 15X10 W/ 7.5 BS
HOLESHOT WHEELS
http://www.holeshotwheels.com/
Holeshot Holestars
Fronts 15x4 with 7/8" spacer total BS 1 7/8" , No need to change studs, wheels come with McGard long shank lugs/open end
Rears 15x10 with 7/8" spacer total BS 7 7/8" , No need to change studs, wheels come with McGard long shank lugs/open end
MORE INFO ON S197 FORUM
HOLESHOT WHEELS
Holeshot Holestars
