SUSPENSION PROBLEM.
vico's97
ok, first thank you all for all the reply's from my last thread. but i have another question,, how can i lift my mustang suspension (just an inch or 2) its too low been hitting everywhere. are the coil spacers gonna affect my riding??
Well have I got a deal for you..... There is an suspension install today at Miramar Hobby shop I believe at about 9:00 am or so and a fair amount of guys with suspension know-how will be there. they can answer many of your suspension questions and even show you a thing or two. I am in the learning phase as far as that is concerned myself. If time does not permit i'm sure whenever they get done with that install and make it on here they will be able to answer this. best of luck on correcting this issue. My first novice answer would be to change out the springs to a different size unless it is a issue of being too soft and an adjustment of sorts is needed to stiffen it in order to dampen the suspension travel.
did you put lowing spring???? Lots of people put lowering springs and forget to change out the pinion snubber which will hit all the time.. Very easy to remove and replace with a lowering one...
This is your pinion snubber... located just above your rear end (pumkin)
vico's97
the car i bought it like that, but yes it has the tokico lowering kit, i will have to check if they put the pinion snubber, thank you ..
northerncountry
vico I will help you out, what suspension are you running totaly, if you don't know it's ok, does it hand the tokico shocks and eibock or h&r springs, we will get it all figured out!
vico's97
i do know it has the tokico blue shocks, not sure about the springs but they look like the tokico springs they are blue also,, i really like the way it handles its just that is too low.. if i put the spacers will that affect my driving??
