Shane361
Been researching all over the net still no luck. My Mach has a very common issue with many other Machs it seems. The driver side window will not go down or up. I use to be able to tap on the door and it would move but nothing now. All I get is the click click. Things I have done thus far...removed the motor and opened and all is fine. Bench tested and works great. The switch also does nothing for the passenger door. I can however use the passenger door and that window works fine. I believe that illimiates the relay and all fuses are good. I tested behind the swith to the wires going into the switch and got a good reading. I am not sure if that means the switch is good or not. Not sure how to test comming out of the switch. Any help greatly appreciated.-Shane
