high idle issue
Sammy 5.0
So when I drive my car and I pull to a light to stop my rpms go up to about a 1000 sometimes 2000 can anyone help please cause it's wasting my gas.......most of the time if I Shut my car off and let it sit for a couple of minutes it goes to normal but I want to fix it.....thanks in advance
Can you post a pic of your engine bay?
1. once you check for Lose MAF and Sensor.
2. Check all your vacuum hosed one may have popped off somewhere and you might want to check your throttle position sensor
Sammy 5.0
I have a collapsed hose coming from the passenger side going under my intake manifold
Sammy 5.0
I unplugged the tps sensor while the car was idling and it idled normal but the check engine light came on......so you think I should clean it or replace it?......thanks for all the advice and tips guys I appreciate it......and I'll make sure I'm at the November meet so could it just be dirty?
Need to stop by so we can hook it up to code reader and get to the bottom of your issue
You just need to take it off the car and clean it. I used break clean. Spray some break clean on a rag and rub it clean. I also used Q-tips.
That hose needs to be replaced as well.
Sammy 5.0
So I got some carb cleaner and took off my iac valve and sprayed it real good took q-tips and cleaned it I also took off the tps sensor and did the same to the inside housing and so far so good thanks guys
