Hey, I talked to Greg a bit ago and I have a question. Would having the stock spark plugs with a -3 degree timing cause the detonation, cause he said try a 2 colder plug. I want to know before I get anything and I will check them when I get home.
Do you have aluminum heads? If so than you need to run a colder plug. What plugs are in it now? -3 degrees timing means nothing if we don't know what the total timing is. I don't care if the car was tuned for 87 that is not a good idea to run the car with 87. Especially the way you race it at the track.
