orange, is there a scanner that can be plugged in to a 5.0 computer???? Or do you have to use one of those timing tools to check the timing on a 5.0????
I checked them all, all of them are good, except for one that I couldn't chack because I think it might be crossthreaded. I am taking it somewhere tommorow to get checked. And probably have them use a compression tester too. And are you sure that I don't need any colder plugs?
The larger the gap the better, but those are recommendations. Every car is different, one car may like .54 another may like .45. The more you can get away with the better. You shouldn't need any colder plugs unless you have N20! I use those in my 393 and they work fine. My plugs are gapped at .45 and the car runs good. You keep dumping money like water instead of doing the basics first.
