I wouldn't buy a rebuild kit for it. I would buy the Eaton locker for 28 spline axles. Seeing as how the Centri blower doesn't make huge power off the line I think the axles will be fine. As for the springs you would be better off putting some stockers back in. I wouldn't use those trick springs that I gave you.
What gear are you going through the traps in? You still didn't answer what gears you currently have. If you are at redline in fourth gear than stepping up the gear ratio isn't going to help unless you went with a taller tire. What tire size do you have?
she has 3.73's and i cross the line in 3rd gear, i was considering the 31 spline but if you say so i will take your word for it on the 28 spline.
