fangs99
Well maybe if jay could work 3 pedals then maybe jay and could swap cars.
you ran 13.5 with drag radials, disconnected sway bar, no back seat, no passenger seat, with cool down time in between runs.
i ran 13.5 in an automatic, misfiring (pretty sure nate said complete misfire), timing being pulled (bad knock sensor), street tires (3 year old reiken raptors from my v6... UGH!) at 35psi, full interior, hot lapping, and sway bar connected.
and now you wanna race a race quad vs. a minor bolt on mach. :nonono:
when you came to the track firday, you said you told everyone you were gonna gut your mach. everyone except me. wonder why? maybe you knew i woulda done the same thing?
i'm happy you ran a 13.5 your first time at the track in your mach. i did the same thing first time at the track in my mach also. :laugh: differences are what i stated.
also now you're spinning all the way through first? your dad told me when you left you slightly chirped and then hooked. i even remember something about looking over the christmas tree after doing a burnout / launching. broke loose at the 1/8th? funny, that night i had none of that. who was running street tires again?i just wanna make sure. for DRAG RADIALS to:
i think you need to get your money back. you're running the same way me and charlie 2 ran on our STREET TIRES. so i guess all the money you spent on those toyo proxies was garbage, huh?
i know all the money i spent getting my mach to run right is garbage until i get traction. :nonono:
now now children.. We are supposed to argue with sd not our own chapter...
now now children.. we are supposed to argue with SD not our own chapter...
no not garbage... if you know anything about cars or tires you would know that a brand new set of DR's don't hook there best till you get a couple heat cycles through them and wear them down some... he's DR's garbage... he ran faster then you with 7 cylinders, no rear seat, drag radials at 13lbs, no passenger seat, disconnected front sway bar, and a cold air exhaust vrs your tune, mid pipe, connected front sway bar, street tires at 20lbs, full interior, and catback.
but i guess your auto can still run as fast as a 5 speed right??
oh and you didnt run 13.5 with a dead cylinder and knock sensors pulling timing... NO ****ING WAY!
you have no idea when your car started do that
Jay bud, I'm not trying to knock on your 13.5 pass but it doesn't really hold any weight...... the only way for the 2 of you to get a FAIR comparison of your and Shane's cars is to run them at the same day same track at about the same time and in the same lane. meaning that ya'll should make a pass one right after the other.
oh and by looking at shane's fastest pass......his time slip shows that he only got a 2.1 60 ft and your getting 2.0's??????
now i remember a time when you would call this a SHANE EXCUSE-O-METER
post.
